Hello All TE friends, One of my friend requires to assemble a pc for photo editing work & budget is 20k. He strictly wants a Intel setup even though I tried convincing him for AMD setup. So, plz help us now with your valuable inputs. Thank you
1. Q: What is your budget?
1. 20K
1. CPU - Intel P4
2. Motherboard - Intel original
3. GPU - Onboard
4. RAM - Kingston DDR 1 gb
5. Monitor - Samsung 17 inches
6. SMPS - Local
7. CD & DVD drives
8. Speakers - Creative
1. Monitor Samsung 17 inches
2. CD & DVD drives
3. Speaker Creative
1. CPU - Intel i3
2. Motherboard - any compatible motherboard which is cheap & good.
3. Any good cheap spacious cabinet
4. SMPS CM GX 550 or Corsair VX 450
5. DDR 3 1X1 GB
1. Yes, will upgrade the following after 6 months
2. GPU
3. Cabinet
4. RAM
5. Monitor
1. Delhi , either Nehru place or any local TE vendor.
1. No
1. Mainly work
2. Browsing
3. Movies
4. Gaming
5. Download rig
1. Yeah want to buy only Intel Config.
1. Any game which can be played
11. Q: What is your preferred monitor resolution for gaming and normal usage
1. No prefrence as such.
1. No
1. Windows XP SP3
1. 20K
1. CPU - Intel P4
3. GPU - Onboard
6. SMPS - Local
7. CD & DVD drives
2. CD & DVD drives
3. Speaker Creative
1. CPU - Intel i3
5. DDR 3 1X1 GB
2. GPU
3. Cabinet
4. RAM
5. Monitor
1. No
1. Mainly work
2. Browsing
3. Movies
4. Gaming
5. Download rig
1. No
1. Windows XP SP3
