Shayem
Hello everyone!
It's been long I've assembled my desktop and planning to upgrade now. Following are the components I'm using in stock settings:
i5 3570K
Maximus V Gene
GTX670 DCU 2 2GB DDR5
2x4GB Corsair Value
Antec EW 650w bronze
Windows 11 pro
I already have 4x8GB DDR4 C14 RAM, which I'll be using. I'll add AIO coller later and upgrade other components as well. I'll be doing continious CPU intensive work ( For example: 4xVM live at-a-time) and concerned about power consumption of whole rig ( has plan to get a platinum or titanium PSU later ). GPU I'll upgrade later and didn't consider PCIe 5.0 while selecting the combo. I've following in mind, as these I can fit in my budget for now. I've already done some research and found both combo has their own benefits but perform nearly same. So asking for some openion to decide between tow combos. Following are the combo I've in mind, feel free to advice different combo if you find more suitable and fit whithin same budget.
AMD: 5900x with ASUS ROG Strix X570-E Gaming WiFi II (will get 5950x if price suddenly come down or I get a good deal)
Intel: 12700k with MSI PRO Z690-A WiFi DDR4
Thank you all in advance!
i5 3570K
Maximus V Gene
2x4GB Corsair Value
Windows 11 pro
