hi all, where can i buy fans for DVD burners in india. any idea and how much does it cost. thanks
K kudilkrishna Disciple Jan 19, 2010 56 0 66 41 Mar 11, 2010 #1 hi all, where can i buy fans for DVD burners in india. any idea and how much does it cost. thanks
H2O Skilled Feb 10, 2008 1,564 25 61 Mar 11, 2010 #2 I don't know but why would you want to buy a FAN for a DVD Burner ? Can you specify your problem properly...Maybe you can use a 90/120mm fan ?
K kudilkrishna Disciple Jan 19, 2010 56 0 66 41 Mar 11, 2010 #3 H2O said: I don't know but why would you want to buy a FAN for a DVD Burner ? Can you specify your problem properly...Maybe you can use a 90/120mm fan ? Click to expand... coz i use multiple dvd burnings at a time and after writing some 50 dvds, i get a some burning smell from the roms.
memnom Adept Nov 21, 2006 969 56 117 Mar 12, 2010 #4 u got a burning smell? with a lil smoke? i think ur dvd has just gone kaput mate. or it will soon.
S saumilsingh Skilled Mar 17, 2005 3,329 162 153 Mar 12, 2010 #5 Lol man, don't burn 50 discs at once. Consumer grade burners aren't built to handle such load.
