t1ruda
ok...so whats the crysis???
my Pendrive and 1tb Freeagent was hooked on. Now I was trying to format the pendrive with "HP USB Disk Storage Format Tool"...but my freeagent was selected on the tool instead of pendrive...I saw this after initiating the format and I rightway cancelled it....
Now the real question is..shall I do the data recovery option or Partition recovery option.??
can you guys suggest some good software which worked for you...
