1. Q: What is your budget?
a. 65K and 20K
2. Q: What is your existing hardware
configuration (component name -
component brand and model)
a. None
3. Q: Which hardware will you be
keeping (component name -
a.
4. Q: Which hardware component are
you looking to buy (component
name).
Monitor:- Samsung 2233SW
5. Q: Is this going to be your final
configuration or you would be
adding/upgrading a component in
near future. If yes then please
mention when and which
component
a. No
6. Q: Where will you buy this
hardware? (Online/City/ TE Dealer)
a. Mumbai
7. Q: Would you consider buying a
second hand hardware from the TE
market
a. No
8. Q: What is your intended use for
this PC/hardware
a. High end Gaming
b. Browsing
c. Download rig, 24x7 operation
d. Watching HD movies
9. Q: Do you have any brand
preference or dislike? Please name
them and the reason for your
preference/dislike.
a. None
10. Q: If you will be playing games then
which type of games will you be
playing?
All Types from Low to High
11. Q: What is your preferred monitor
resolution for gaming and normal
usage
1. Gaming - 1920x1080
2. Desktop - 1920x1080
a. No
13. Q: Which operating system do you
intend to use with this
configuration?
a. Windows 7 64 bit
Guys the Above Template applies for both the configs...The 65k config will be used by me & 20k config by Father.
Note:-Watching HD Movies dont apply to 20k & nor the monitor...Its selected for 65k
Preffered format for 65k:-
CPU --> AMD Phenom II 550 BE (i know unlocking)/AMD Athlon X4 630/Intel core i3 530/ or better that could fit in my budget
Mobo --> undecided
Ram --> 4GB
GPU -->
Undecided
HDD -->
2TB
Monitor -->
Samsung 2233SW
Speaker --> undecided
Headset -->
Steelseries Siberia v2 (i own it)
Soundcard -->
undecided
Powersupply -->
undecided
Chassis --> undecided
blu-ray burner w/ lightscribe[DVD/CD/BD] --> undecided
Keyboard --> undecided
Mouse --> Razer Deathadder (owned)
Network Card --> undecided
No Response
Awkward
please-someone help...reply
a. 65K and 20K
a. None
a.
name).
component
a. No
a. Mumbai
market
a. No
this PC/hardware
a. High end Gaming
b. Browsing
preference/dislike.
a. None
playing?
usage
a. No
configuration?
a. Windows 7 64 bit
Mobo --> undecided
Ram --> 4GB
GPU -->
Undecided
HDD -->
2TB
Monitor -->
Samsung 2233SW
Headset -->
Soundcard -->
undecided
Powersupply -->
undecided
No Response
Awkward
