What is your budget?
- 150k - 175k
- 150k - 175k
- Fresh Build (Apart from peripherals - Mouse and Keyboard combo Logitech K-260)
- Mouse and Keyboard - Logitech K-260
- CPU - Intel Core i5-8600k
- Motherboard - ASRock Z370 Killer SLI/ac LGA 1151 (Any other compatible motherboard suggestions?)
- GPU - GTX 1080ti
- RAM - 16 GB (2x8 or 1x16 whichever’s more convenient) (Found Crucial and Corsair at the top in Amazon’s popular products)
- SSD - Samsung 960 EVO 250GB NVME M.2 SSD V-NAND MZ-V6E250BW
- HDD - Seagate Barracuda ST2000DM006 2TB HDD
- PSU - Corsair CS-M Series CS750M (Newegg Link for ref)
- Cooler - COOLER MASTER LIQUID COOLER - MASTERLIQUID LITE 120
- Case - Corsair Carbide Series CC-9011050-WW Mid-Tower Steel Gaming Case with Red LED (Black)
- Yes, will upgrade the following (as per required in the future)
- RAM - Extend from 16 to 32
- Pune (Thinking of getting all the parts from one store if possible, so that return policies and warranties can be handled appropriately)
- Open to online purchase
- No
- No
- Deep Learning
- Will be used to train models, which could go on for multiple hours, days even)
- Heavy computations on GPU
- Deep Learning
- No. But would appreciate a reliable manufacturer with good post sales service
- No
- No
- No preference. Would love some suggestions.
- No. ( Have never overclocked a CPU ever. So don’t know if I would require to, in the future)
- Windows 10
- Linux - Ubuntu (and any other distro)
- Windows 10
1. I have checked basic compatibilities like CPU-Motherboard chipset compatibility and multi-GPU SLI support if required.
I need help checking for overall compatibility of the build. Open to suggestions.
3. Any compromises if at all visible in some components might be due to the priority given to 1080ti. (Like CPU)
4. Any misfit items chosen might be due to my inability to understand
