Hello all,
I need help building a PC for Storage, Plex, Home Automation services (Home Assistant, etc).
Need help wrt PSU, Case. Please suggest if you think a better Motherboard choice is available.
- What is your budget?
- 135K
- None
- NA
- CPU - i5-13600k
- Motherboard - Msi Pro Z690-A DDR4 (Please suggest if you think something cheaper/better is available. I chose this because it has Intel NIC and 6 SATA ports)
- GPU - Not required. Max I have 1 1080p FireTV stick that needs to transcode. Intel iGPU will suffice.
- RAM - Corsair Vengeance Lpx 16Gb DDR4 *2
- Cache disk - Samsung 980 500GB *2
- HDDs - WD Ultrastar DC HC550 16TB *2
- PSU - Need help as it will run 24*7
- Case - Need help. Preference to quiet, cheap, at least 6 3.5" HDD bays
- Yes, will upgrade the following within 24 months
- Add more HDDs
- Bangalore
- Open to online purchase
- NAS
- HTPC
- Home Server
- Download rig, 24x7 operation
- Do not want to buy XYZ company product as I heard the after sales service in India is pathetic
- No
- Unraid
