Need help for buying electrical appliances
sasikanth8
Explorer
Our new house is almost complete so looking for buying new electrical appliances:)
I compromised my self to buy most imported things first and buy one by one
1) LCD TV(my 10 year old onida28XL stopped working)
1. Budget.~35,000 to 40,000(lower the better)
2. Viewing distance.~10feet
3. Sources/inputs such as HD DTH/consoles/stand-alone media players etc.~cable
4. Preference for plasma TV/LCD TV/LED-LCD TV.~lcd
5. Preference for brands.~samsung/onida/sony
6. Willing to purchase it from the grey market?will be going to chennai soon will consider buying if its good deal
7. Ambient lighting conditions of the room~.there is lighting from side and opp to TV any tips are appreciated:clap:
8. Any other feature you are looking for such as 3D support on the HDTV, DLNA capabilities etc.~dlna if possible
2)Refridgerator(~200ltr) budget~10,000
Would be using mainly for storing vegetables.Dont have much knowledge on fridges as i haven't used one.
3)Kitchen Hood~10,000
Dont have any idea about this even if i need one:ashamed:.
Thats all for now will think about other appliances after finalizing on these.
Bumping thread for suggestions.
Guys help me.
For TV,
I would suggest get ips panel TV.
I suggest LG Panasonic and Toshiba.
some of te best
fridge, buy whirlpool or LG.
I have double door whirlpool 220 or so doing faithful duty for last 8-9 yrs.
Sent from my NookColor using Tapatalk
For TV, I wud say panny s20.
Fridge, I am using a whirlpool for last 9 years without a hiccup.
Sent from my GT-I5801 using Tapatalk
I am using Hindware - got for Rs.4500 odd about 2years back. Try getting one with baffle filters (the ones with long steel plates) as they are easy to clean. Also make sure you switch it on at the outlet and check the noise levels, as the the cheap ones can be quiet noisy. 10K is a decent budget for hood.
sasikanth8 said:
How is the Hindware you are using does it have filters? and noise levels?
Its got mesh filters which are a bit problematic to clean. And yes its quite noisy.
A costly hood will be quiter, thats what the high price is for.
