71-90K Need Help for CG Interior design system.
Robben05
Beginner
Hello we at our Interio Design studios create life like 3D views. (No walkthroughs) just still images for approval from clients.
Planning to upgrade my system need help deciding decent spec for the same my budget is max 70k -80k.
I know and dont know a few things as mentioned below.
1. Z97 Chipset from gigabyte.
2. 4790K i7 processor or just 4790 i7?
3. 16Gb of ram
4. 320gb or 500gb Hdd (Ssd not req)
5. Cooler required? (Render will take place mostly over night without any ac on in delhi heat?)
6. Good quality monitor for analysis of color but good price too.
7. Power supply?
8. Cabinet?
9. Graphics card for rendering? (No clue here whatsoever)
Please help with getting my configuration up at proce point mentioned.
Awaiting kind help from members.
Budget - 85k (Modified)
Processor Intel Xeon E3 1246 v3 21,000
CPU Cooler
Cooler Master Hyper TX3 EVO 1,700
Motherboard
MSI H97 PC Mate 6,500
Memory
Kingston HyperX Fury 16GB(8GBx2) 1600Mhz 6,400
Graphics Card
Leadtek Quadro K620 13,500
Power Supply
Antec VP550P 3,900
Cabinet
Corsair SPEC-03 4,300
Internal Storage
WD Caviar Blue 1TB HDD 3,600
Monitor
Dell Ultra Sharp U2414H 23,000
Keyboard
Logitech MK200 Keyboard & Mouse Combo 800
Mouse
Included in combo 0
Total 84,700
Hi Thanks for your reply bssunilreddy. I have finalised following configuration after giving dew thought to future availability of CPU I want to go for i7 and not xeon processor. Anyhow my Vendor suggests me to go for gigabyte's Z97 mother board, Instead of B85. I am a bit confused please help.
1.CPU I7 4790
2. GIGABYTE B85MD3H OR Z97 OR H97?
3. RAM CORSAIR VENGEANCE 1600 8GB X 2NOS
4. PSU SEASONIC M12II520
5. SAMSUNG SSD 850 EVO 250GB
6. GPU LEADTEK QUADRO K620
7. CASE CORSAIR SPEC 01
8. 21" MONITOR (YET TO FINALIZE)
i am quite confused about motherboard please suggest some and list difference between these. I don't intend to overclock this system at all and it'll be used mostly by my staff only. I am yet to finalise on monitor and ups.
Also can anyone point me to right shop at Nehruplace or Wazirpur delhi to buy the same?
1.CPU I7 4790
Go for H97 mobo. dont go lower than that.
If possible try to accommodate a bigger monitor,bigger the screen real state better for this stuff
@Robben05
You can save a lot just by going with an H81 motherboard, though you'll only get 2 USB 3 ports.
You can get it for 3-3.5k.
These are the best shops in Nehru place (AFAIK) - SMC international, Cost 2 cost and Computer empire. You don't need to look anywhere else
Thanks for your reply guys. I bought my system last monday from cost to cost. I bought H97 mobo.
Now am facing storage issue ssd is less for 3d files. I am planning on buying additional 1tb hdd confused between WD 1TB Blue or green or Seagate baracuda 1TB. Please suggest.
WD BLUE 1 TB ,in my opinion
Greens are just a little cheap W, but not much, and are generally considered slower (5400 rpm)
