Need help in buying 32 inch LED TV
matrixvipin
Contributor
I am planning to buy 32 inch LED TV HD Ready.
It should have usb support to play videos.
Viewing distance 6 to 8 feets.
Room light normal to dark.
Budger 25 to 30k.
Use the search on the forums mate.. a lot of threads already discussing this.
Secondly, if you're going all the way to 30k whats the point of HD Ready? At 32/32.5k is the LG LS4600 Full HD LED Tv.. worth every rupee
I have short listed 2 tvs
1. Panasonic TH-L32XM5
2. Samsung UA32EH4000
Which one is better?
Also one confusion, in Panasonic there are 2 versions of same model Panasonic TH-L32XM5, TH-L32XM5D.
Are these same or different? Bcoz I have confusion reading features from various websites that one of (TH-L32XM5D) it can play various video formats while other cannot (TH-L32XM5).
