k_m_Arya
Galvanizer
I use corona and maya(still learning) and sometimes vray when I need to..
Open cl is easy,cuda is well a bit tough to master
Which is better Ryzen or i5 7500
Btw do I need a aftermarket cooler or stock ones will do the trick?
I'm thinking the same thing,to go with bssunilreddy's build but replace some parts with manjeets build
All of those use cpu rendering right? Will you be using any gpu rendering software?
I would suggest this build:
Ryzen 5 1600 - 16500
GIGABYTE AB350 GAMING-3 - 8500
CORSAIR VENGEANCE LPX (16GBX1) - 9000
WD 1TB BLUE 7200 RPM - 3500
COOLER MASTER MASTERWATT LITE 600W - 4400
Corsair 270R - 5000
GTX 1070 - 30000
If you can spend a little more then buy an ssd too.
