rohan30186
- What is your budget?
- 8-10K
- CPU - Intel Q6600
- Motherboard - MSI - P35 (dead)
- GPU - ATI 5770
- RAM - Transcend 2X2GB
- Monitor - Dell 22inch
- PSU - Gigabyte 460
- HDD : WD 2TB, Seagate 1TB , WD -320gb
- GPU - ATI 5770
Not Decided . Need Motherboard + Processor + RAM .
No planned upgrades
- Mumbai
- Open to online purchase
- Yes
- Browsing
- Download rig, 24x7 operation
- Watching HD movies
- No preferences
NFS Series , rarely
- Gaming - 1280x720
- Desktop - 1440x900
- No
- Windows 864 bit
Need a basic configuration - more for the internet needs. If any one can help with the motherboard for Q6600 then that could possibly be enough.
Budget is very low and prefer as cheap config as possible - only thing it should not hang if I open few applications in parallel
