Need help regarding fit issue of triplefi
lavii
Contributor
Hi all, i have recently got triplefi from amazone deal.
the problem i am unable get proper fit with any of the supplied tips even with comply foam. comply just sits outside of ear.
i am regular use of shure 535, they fit perfectly, also the comply for shure is little long as compared to triplefi's comply.
please suggest some good tips as there are many triplefi users are here, also give some suggestions for following:
--how is sony hybrid tips
--is there any comply other than t500, that fit triplefi
--anyone using moded tips
--anyone tried shure olive mod, as i don't want to destroy shure tips (already destored other tips)
The tf10's have a pretty big ear piece. It is normal for the ear piece to be outside the ear but i'm sure the comply foam sits securely inside. Are you using the comply correctly. Your supposed to squeeze the tips gently to compress them before inserting so that the foam deflates after you've inserted the in your ear. This gives a perfect seal.
thanks benny for reply, i am doing right after expanding comply comes out of ear, i think medium size comply is not for me as nozzle is already big, may me small size will work
