Hi
I have a system that I use for watching movies (HD some times) and gaming. It's been doing fine so far, but recently my motherboard has gotten damage. The system doesnt post and the cpu fan spins for a tenth of a second and stops. I checked the PSU and the cpu fan independently with a working system and they are ok.
My system used to be
a 700 W Corsair PSU
an ASUS p5be socket 775 mobo
2 1 gig sticks of 666 mhz ddr2 ram
an ATI 4890 video card
a core 2 duo, e6600
So far my rig worked as a downloading/watching/gaming rig, though Ive felt Im a little low on Ram, especially if I want to upgrade to Windows 7.
Now I have to replace my motherboard. Do people recommend just getting a new socket 775 motherboard and some ram? Should I replace my current ram sticks or use that alongside the new ram?
OR
that I get a new motherboard for the newer series of chips, an i3 or i5 and ram with that?
My budget works for either of those options, but I'd rather not upgrade unless I can expect a significant benefit for my current use case. Or if it becomes cheaper in the long run.
Additionally, I want to build a RAID5. I want this simply for the redundancy, not so much the speed. I'm just tired of storing movies on dvds, but I have lost hdds before. Should I get an onboard raid controller on a motherboard, or do you recommend an add on card?
thanks
a 700 W Corsair PSU
a core 2 duo, e6600
OR
thanks
