kushall
Hi all,
Please suggest me the components i can upgrade in my current PC so i can play the latest games like Battlefield 4, COD Ghosts and such. Thanks 6pack for moving this thread.
- What is your budget?
- 35k?
- CPU - Intel E6300
- Motherboard - Asus P5B Deluxe
- GPU - ATI Radeon 4850
- RAM - Transcend 2X2GB 533mhz
- Monitor - Veiwsonic 19"
- PSU - Coolermaster Extreme Plus 460W
- Zebronics Antibiotic
- PSU - Corsair VX450
- CPU - AMD FX8320
- MB - ASUS M5A97
- GPU - R9 270x
- RAM - 4 GB or 8GB 1600/2133 mhz?
- Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which componen
- Bangalore
- Open to online purchase
- Yes
- Gaming
- FPS - CS-GO, Battlefield 4, COD - Ghosts
- RPG - Dota 2, LoL
- Gaming - 1440x900
- No
- Windows 7 64 bit
