Questions
What is your budget?
30K
What is your existing hardware configuration (component name - component brand and model)
GPU - 1660 super
Monitor - LG 22 inch 1080P IPS monitor
Logitech mouse and keyboard
Which hardware will you be keeping (component name - component brand and model)
Monitor,GPU,mouse+keyboard
Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
CPU - RYZEN 3100
Motherboard - any compatible motherboard with an M.2 slot
RAM- 8GB (don't know what brand to choose)
PSU - Best Power Supply Units (will a 550W be enough?)
Storage - 256 GB SSD(M.2)+1TB WD blue
(please mention the rest in above format)
Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
Yes, will upgrade the following within 4 months if prices for something like a 1080 drop
Where will you buy this hardware? (Online/City/TE Dealer)
Bangalore
Open to online purchase
Would you consider buying a second hand hardware from the TE market
Yes
What is your intended use for this PC/hardware
Gaming
Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
I just want a RYZEN build
If you will be playing games then which type of games will you be playing?
FPS - CSGO , APEX
A mix of other games like witcher 3,AC,also cyberpunl
Racing - Forza at high settings
What is your preferred monitor resolution for gaming and normal usage
Gaming - 1920x1080
Are you looking to overclock?
Mostly no
Which operating system do you intend to use with this configuration?
Windows 10
30K
GPU - 1660 super
CPU - RYZEN 3100
Bangalore
Yes
Gaming
FPS - CSGO , APEX
Gaming - 1920x1080
Mostly no
Windows 10
