flippertom
Recruit
1. Q: What is your budget?
20K
1. CPU - Intel p4
2. Motherboard - intel
3. GPU -none
4. RAM - Transcend 2X1GB PC6400
5. Monitor - samsung syncmaster b2030
1. Monitor - samsung syncmaster b2030
1. CPU - Intel core i3/amd phenom ii x2
2. Motherboard - any compatible motherboard
3. Transcend DDR3 2x2GB
4. Seagate 500GB SATA
5. DVD Writer
6. Cabinet
1.GPU
1. Pune(need help...suggest a good dealer)
1. No
1. Gaming
2. Browsing
3. Desktop Processing
4. Download rig, 24x7 operation
5. Watching HD movies
None
11. Q: Are you looking to overclock?
1. No
1. Windows xp
2. Windows 7 32/64 bit
20K
1. CPU - Intel p4
3. GPU -none
5. DVD Writer
6. Cabinet
1.GPU
1. No
1. Gaming
2. Browsing
None
1. No
1. Windows xp
