budget is not clear.. but i want good mobo+cpu which i can use for 3-4years.. not tooo hi-fi mobo... yes i will be buying a graphics card..thinking GTX560Ti or 570..
The nVidia GTX 570 is taken out of the race as the AMD HD 6950 1GB offers much better price / performance and consumes lesser power on the whole, suffice to say a much better deal than the power-hog architecture that nVidia endorses currently -- AnandTech - Bench - GPU11.
@nuke'em and Alpha17: thank you very much for your replies...
currently i have: Intel Core2Quad 9450;ATi 4870 and Corsair TX650...
i have also used ATi4850 on the same config before 4870. i am not very happy with ATi as it always use to have some or the other problem with one or the other game i played. so thought of going Nvidia way this time..
The mobo ASUS P8H67-M EVO has a 2nd PCI-Ex slot which i dont need.. i will simply end up paying for it. can you please suggest some other models?
Also if you are going to get an i5 2500, just spend a couple of hundred bucks more and get the K version. If at any time you need to use the IGP, the 3000 will be much better than the 2000 version on non-K SKU.
Also, better resale value. Plus these will be the better binned SKU's.
