Kaleen Bhaiya
I recently bought a new hard drive to replace my 320 gb old one. Now I want to use the old drive as a media device or backup by converting it to an external portable hard drive.
I was going through Amazon and found this link..
I have following questions.
1. How do I know if my old drive is Sata 2 or Sata 3. I got it in 2007-08. Will putting it in a USB 3.0 enclosure help it achieve good speeds? I do know that it runs at 7200 rpm.
2. Can it provide a decent data transfer if I try playing 4K content on my TV from this drive?
Or I should instead get a USB 2.0 casing as my drive is old hence I won't be able to take advantage of the 3.0 casing/connector port.
I am a bit confused as this is my first external case.
Any help would be appreciated.
Thank you.
Thank you.
