YoGi-Sama
Galvanizer
I'm taking a trip next month... where there will be lot of traveling involved on road as well as less electricity on stop.
So in search for solution to charge my gadgets, I came across this : eBay India: CAR 12V DC TO 220V AC + USB INVERTER CHARGER SVB-0043 (item 350065483569 end time 06-Jun-2008 15:47:24 IST)
I'll be carrying my DSLR with a spare battery (and charger), a camcorder with bigger battery (and charger), my iPod, cellphone and laptop. Of which, I would require to charge mainly my camcorders smaller battery, occasionally my DSLR's battery (it will be mostly day shooting, so battery can run longer), my iPod and laptop.
What I would like to know is... does anyone here has any first-hand experience with similar product? How well does it work? What are the down points? and if at all, is it advisable to get one of these for the trip?
EDIT :
If at all, it is all ok to buy such product... does it make big difference to go for branded one over cheaper non-branded one?
Like this one : eBay India: APC 150W DC to AC Inverter with Auto & Airline Adapter (item 380027668407 end time 13-Jun-2008 15:51:43 IST)
Also, if one to get such product... which is better option in terms of output... 150w or 350w? Is it viable option to go for 350w? or 150w should suffice the need (charging at least 2 gadgets at a time)?
EDIT :
