Arpan Naithani
Recruit
Questions
- What is your budget?
- 22-25k (max)
- CPU - Intel Core 2 Duo, E4500, 2.2Ghz
- Motherboard - G41M Combo
- GPU - Nvidia GT220 1GB DDR2
- RAM - Kingston 1x4GB DDR3 1333Mhz
- Monitor - HCM710LSA, 17inch
- PSU - a cheap Zebronics i think, don't remember the details
- HDD- WD Caviar 500GB
- (please mention the rest in above format)
- RAM- Kingston 1x4GB DDR3 1333Mhz
- CPU - AMD Fx 6300, I'm open to other suggestions provided they are in the same budget brackets
- Motherboard - any compatible motherboard
- GPU - Sapphire ATI 7750 1GB DDR5 again, open to other suggestions in the price bracket
- PSU - anything from a decent company, able to handle the above config (preferably around 2.5k)
- Cooler- Suggest if the stock cooling solution would be inadequate
- Yes, will upgrade the following within 6 months
- RAM - will be adding 8GB more, compatible to the existing RAM
- New Delhi
- Open to online purchase
- No
- Gaming
- Browsing
- Watching HD Videos
- Emulation of consoles PS2 and Wii
- No particular preference or Dislike
- Grand Theft Auto V (if its released, hopefully
- Saints Row IV
- Assassins Creed IV
- Crysis 3
- BF 4
- FIFA 14
- Need For Speed Rivals
- not expecting to play games at high settings, or with AA, also i'm happy with averaging around 25 fps
- not going to play multiplayer
- Gaming - 1280x1024 ; sometimes on my TV at 1680x1050
- Desktop -1280x1024
- Are you looking to overclock? No
- Windows 8 64 bit
