My 22" viewsonic went kaput sometime back, I think the back light went kaput. Have been using my 17" compaq crt since then, but I think its time for an upgrade.
I checked out 24" led's but they didn't seem that much bigger than my 22" 16:10 viewsonic, they only seemed to be a bit wider.
So have decided to go in for a 27 incher, but cannot decide between the following.
Acer S273HL - Its a TN panel with LED back lighting, I liked it. but this review discourages anyone from buying it :huh: Got a quote of 19k for this from prime.
Benq M2700HD Again a TN panel, has ccfl back lighting, so is thicker. Has speakers and lots of connectors which i do not need. Got a quote of 23k for this. I dont know if I should trust ccfl backlit lcd's since my viewsonic went kaput 1 day after the 3 year warranty got over.
BenQ EW2730V Its has a VA panel with LED back lighting, I liked this too, but it is no where to be seen :huh:
My primarily use will be for watching movies and browsing the internet, I feel 1920x1080 should be adequate for that. I can spend upto 25k. Which one should I go for?
