I currently have a 15.6" laptop and i find it very tiring and difficult to work on the laptop for long so i m thinking of buying a new monitor which i can connect to my laptop and use a wireless keyboard and mouse with it.
Main requirements are :
1. 27inch (1440p will be preferred a lot)
2. Main usage will be coding, surfing the web, blogging etc (Not going to use it for gaming)
3. IPS panel or any other panel which will not strain the eyes. I will be using it for about 8-10 hours daily so it is must that it does not strain my eyes.
4. Budget 22k max (cheaper the better- if 1440p then can extend the budget to 30k)
All suggestions and replies will be appreciated. Thank you!
