Gdn - TD
I'm looking for suggestions for my friend who is building a system for office related work. Any suggestions on what we should be looking for in a system when the main purpose is CAD applications?
Questions
Questions
- What is your budget?
- 60K
- N/A
- None
- CPU - AMD FX 8320
- Motherboard - any compatible motherboard
- GPU - HD7770 1GB
- RAM - Corsair Vengeance 8GB 1600 MHz
- No, this will the final configuration
- Chennai
- No
- Mainly used for CAD applications like Ansys, Abaqus and Hypermesh
- No preference
- Strictly for CAD applications; no games.
- No preference
- No
- Windows 7 64 bit
