PC Peripherals Need to buy USB extension cable for my WiFi USB recever...
alive hunter
Contributor
I have a USB WiFi receiver for my desktop,
Now i need to buy a USB Extension Cable for the same so that i can place the Receiver near the window.
I am looking for a 5meter cabel....
My question :
1. will the lenght of the cable effect the perfomance for the WiFi signal received / Data transfer ?
2. Is the Filter required in the cable??
3. what will be approx cost??
Rgds,
AH
http://www.youtube.com/watch?v=ASQn2KOvHJg
Did you watch the video? OK forgot about it .
Just all you a hi-speed usb cable. Otherwise device does not work.
here is 10ft USB cable.
http://www.homeshop18.com/usb-2-0-high-speed-extension-cable-10-ft-imported/camera-camcorders/accessories/product:15924785/cid:3173/
and the bellow is 2 meter, may be approx 6 feet.
http://www.homeshop18.com/bandridge-pg-mac-prom4302-usb2-0-extension-2-0m/electronics/audio-video-players/product:27746763/cid:3231/
Read the specification carefully. Mainly the speed of the cable must be higher than your device speed.
yesterday bought the 5 meter USB extension cable from Lamington road..
Local quality with filter from Road-side... Rs 100....
But it dint worked...
when i connect my pendrive using it .. it shows error "the drivers was not able to install correctly".... with a exclamation mark.
I think there is some difference between normal usb extention with filter and a high- speed usb extention. Because the price is almost 3 or 4 times than a normal cable. You should ask for a high speed cable.
But with the normal cable pendrive does not have any problem. So i think your cable may be faulty.
There is chance that the speed of the cable is the main guilty. Because I also have a normal cable with filter which do not problem with my pendrive but that does not connect my Usb Modem, which i use for internet, because of speed.
