Audio Need ultra portable speakers help..
d6bmg
BMG FTW!!
I've shortlisted two:
1. F&D E200
2. F&D V620 plus
But I can't choose one above another. Help!!
My max budget: ~700/-
F&D V560, ultra portable and great VFM purchase.
I have both V620 & V560. Both use the same exact driver, but V620 has better bass owing to it's housing may be.
V620 is portable but weighs more due to the heavy metal base.
I liked V620, So I decided to give V560 a try, since my Vaio has crappy speakers. To my surprise this is too good for it's compact footprint.
Moreover they can be clipped onto laptop bezel.
Both run on USB power and both have an inline volume control, you won't go wrong with either of them.
But if you prefer better bass, then go for V620 out of the two, if you want the speakers to be more compact, go for V560.
