neeed help for pc build
princeoo7
On a Journey called Life :P
hello friend ,:cool2:
am building the following thing and dream of my killer ride....
amd phenom ii x6 1055t
gigabyte 890GPA-UD3H
crosair / G.skill ddr-3 ram 2gb on
crosair vx450 smps i think so
but the most difficult thing for me is to think of a good cabinat with good looking body , air cooling and extreme........
plz help me out wit the cabinat and configuration..........
my friend has an gigabyte chaain luxo 142 and i like it :eek:hyeah:
but want to try some thing different plz help
and those r from mumbai plz if possible , plz provide the above configuration rates to ...
thank you all in advance ........:hap2:
cheers to all who live as a gamer and pc users......:clap:
The Cooler Master Elite 430 for 2.7k looks pretty good and has decent airflow if you add an extra fan or two. Gamma seems to be the preferred choice though and it's cheaper.
Like Alpha17 said, follow the template so it's easier to give you advice on your rig.
total budget of Rs.25000 but can try to get a little more if the thing is good but not more the rs. 3000 for cabinat
