Hi guys!
Need some help with my current networking setup at home. It's pretty simple:
Router 1: Dlink 2750u wireless modem+router with an 8mbps Airtel DSL connection on 2nd floor (DHCP enabled).
Router 2: Cisco E900 wireless router on the 1st floor connected to the Dlink router via LAN cable (DHCP disabled).
The LAN cable that connects both the routers is connected to a numbered LAN port on BOTH routers. Both routers have the same wireless SSID and password. This helps in wireless roaming between the 2 routers without dropping the connection. Since the Cisco router has DHCP disabled, all connected devices have their IPs assigned by the main Dlink router. Also, the wireless channels are 11 and 6.
There are approx. 15-20 devices connected on this setup when everyone is home, which is every evening/night.
Problems:
1. The internet stops responding very frequently, literally every few seconds.
2. The range of the Dlink router is not sufficient for the second floor.
3. We will require another router in 1-2 months to cover the 3rd floor.
Now, regarding problem 1, I disabled the wifi on the Dlink router and disconnected the other router to check if the problem was with the Airtel connection. I connected my laptop via LAN. The internet was working perfectly fine. I used the internet for a while, there was no problem. I feel that the Dlink router can't take the load of so many devices running on it's wifi and the connected router's wifi, for which it also assigns the IPs.
So yesterday evening, I changed the SSID, password and also enabled DHCP on the second router to see if everything works fine. The idea was to let the Cisco router assign it's own IPs for the connected devices. The problems didn't go and I realised that the Dlink router was still assigning the IPs. I think I need to attach the LAN cable on the WAN port of the Cisco router for this to work.
The long term solution I've come up with is:
Have a separate DSL modem and have 3 wireless routers installed on it, each assigning its on IPs and running different SSIDs. Now, since wired routers come with only one LAN port, I can use my Dlink router as the "wired router" by disabling wifi on it. Then I can connect 3 wireless routers using the numbered ports on the wired router and WAN ports (maybe?) on the 3 wireless routers. Wiring is not a problem.
How does this sound?
Thanks in advance..
Problems:
Thanks in advance..
