Q: What is your budget?
20K
Dell Vostro 1400 (Running Core2Duo T5470 @1.67Ghz. 2GB RAM, Windows Vista) - How much should I put this up for ?
None. Wish to sell the laptop and get a desktop.
Final config
Chennai
Open to online purchase
No
Browsing
Desktop Processing (Need to run Photoshop/Lightroom)
HTPC if possible
Download rig, 24x7 operation
Watching HD movies
Nop.
NA
Desktop - 1440x900
No
Windows 7
Wish to have a low power 24/7 rig connected to Router and access within the home network. I have an office laptop and wife would use this for chatting/facebook. Would need access from a android mobiles/ipad (getting one soon).
20K
Final config
Chennai
No
Browsing
HTPC if possible
Watching HD movies
Nop.
NA
Desktop - 1440x900
No
Windows 7
