Hi, I want to build a rig to mainly do 3D animations, complex visual effects, rendering 2D and 3D models with textures. The softwares I would be using are: MAYA, AFTER EFFECTS, 3D MAX, etc. I would also be using rendering softwares on the system and probably some games as well.
# Q: What is your budget?
1. 100K- 110K
# Q: What is your existing hardware configuration (component name - component brand and model)
None, want to build a completely new rig.
# Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
This would be my final config.
# Q: Where will you buy this hardware? (Online/City/TE Dealer)
Mumbai
# Q: Would you consider buying a second hand hardware from the TE market
Yes
# Q: What is your intended use for this PC/hardware
1. 3D modelling/ rendering/ 2D modelling/ visual effects
2. gaming
#Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
no such preference.
# Q: If you will be playing games then which type of games will you be playing?
batman arkham city/ asylum, etc
# Q: What is your preferred monitor resolution for gaming and normal usage
Please suggest
# Q: Are you looking to overclock?
No
# Q: Which operating system do you intend to use with this configuration?
Please suggest
Thanks!
DeeJay
1. 100K- 110K
Mumbai
Yes
2. gaming
no such preference.
Please suggest
No
Please suggest
Thanks!
DeeJay
