PC Peripherals Nzxt gamma owners - need help
scudmissile007
Contributor
HELLO ALL,I bought the coolermaster n620 cpu cooler for my pc as my cpu temps were hitting sky high.Now the problem is the cabinet,i am going to buy NZXT gamma on monday will it can accomadate this N620 easily in it or i have to consider any other cabs.Can NZXT gamma owners can tell me the inside dimensions of the cabinet,the n620 is 161mm in height.Plz help.
Re: Nzxt gamma owners need help:(
i am using noctua u12p se2 cooler in the gamma case. it fits properly so i assume even the n620 should fit without any problems.
^^Thank u verymuch stromblast for your help and one more thing u12p se2 is 158mm & n620 is 161mm,is it a comfortable or a tight fit in your gamma?
i am using cooler master tx3 and its very spacious.
i suggest get few nice fan and be done with it.
i took out default (back panel ) fan and put it in front of hdd.
it reduced my temp to 32-33 and
cpu(amd athlon 2x4 635) idles at 35-36.
I have used Thermolab baram, Thor's hammer and TRUE on my Gamma cabby. U cant attach the side panel fan on the top slot. Other than that, all fits fine.
yes it will fit. 3mm will hardly make any difference. only downside with these tower sized coolers is that the top fan slot on the sidepanel cannot be installed.
