Need to buy an oil filled radiator heater, should I buy online and hope it's not broken? Paytm has good deals but never bought 10k worth electronics from them
Have 2 ofr both are 13fins model and work great, Don't buy small like 9/11fin models, I paid around 9k each for them 2 years back. Brand Murphy Richard's.
Also if u want something instant go for carbon heaters bought Orpat yesterday for 2.5k.
I would recommend buying them locally as they are filled with oil and one drop can damage the fin.
As far as I know they don't burn oxygen and I feel are better (instant)then the ofr, Also we don't use normal heaters overnight.
13 fin works with Upto 250sqft and takes
Around 2 hours for proper heating when outside temp is around 3/4°, Also its not proper heating u will not feel the heat like with the carbon or the rod heater it just works like AC. As I earlier said if u want instant heat go for the carbon/rod heaters else OFR
