Hi,
After much of confusion, due to strict budget constraints, finally i will be getting 955BE (used) and Gigabyte 880GM-D2H ver 3.1.
I already have a Arctic Cooling Freezer 7 Pro Ver 2 and one Cooler Master 90 CFM 120mm fan.
I am getting Seasonic 620W SMPS and NZXT Gamma.
I desire to OC the Proccy to 3.8-4GHz.
Now I need some help/suggestion before jumping in to the ring.
Can i go till 3.8-4GHz with that mobo and CPU cooler? (also have XMS3 2*2GB 1600MHz)
If mobo needs to be changed which one i should get ? (in max 4K - except MSI)
If CPU cooler needs to be changed which one i should get ? Actually my budget is 1.3K max but this is tempting me Corsair A50 @ 1970 (after 10% off on Master Card till 31st Dec)
Also which Thermal Paste to buy ?
Also how can i make sure that cooling in NZXT Gamma is best/proper using/positioning fan(s) ?
If more fan needs to be bought i can buy them too.
Regards,
Viral
Regards,
Viral
