So guys I am living in a small two bedroom apartment and I have a basic home theater/recording setup with a nice Samsung TV| Samsung TV 690U Series 50" | HG50NJ690UFXZA , professional Yamaha studio monitors, an Audient ID14 audio interface and a PS4.
I want to build a rig that would enable me to use the Samsung TV as my monitor and I would like to use it primarily for audio production/recording, video editing, some Microsoft office work,streaming and maybe some light gaming.
I need a fast PC which is very quiet because this will be located in the Hall alongside the PS4 and the studio monitors. I don't want to spend too much at the moment, so if you guys can suggest some cheaper options with similar performance, then feel free.
Questions
Questions
- What is your budget?
- 40K to 50K
- I just use a laptop for work at the moment.
- Not applicable
- CPU – AMD Ryzen 5 3600 3.6 GHz
- Motherboard – Asrock B450 Pro4 AMD
- GPU – GTX1050 ti OC
- PSU – Cooler Master MWE450
- RAM- G.Skill 8GB 3200 Mhz x 2
- Cabinet- Chiptronix Raptor
- SSD- Samsung EVO 250 SSD
- Monitor- Using my Samsung UHD TV
- Keyboard and Mouse- Undecided- I need a wireless keyboard and mouse
- I am hoping that this configuration lasts me a few years. I don’t intend on doing massive gaming and just some audio and video production. Microsoft office, streaming etc etc. So suggest me something I can easily upgrade over time.
- Bangalore
- Yes
- Audio Production
- LightVideo Production
- Light Gaming
- Browsing
- Download rig, 24x7 operation
- Watching HD movies
- None
- Nothing in particular
- I want to use my Samsung TV 690U Series 50" | HG50NJ690UFXZA
- No
- Windows 10 | Please suggest if I need to buy the original
