- What is your budget?
- 51-70 K (May go a little higher if needed absolutely)
- CPU - Intel E4400
- Motherboard - MSI
- GPU - No
- RAM - 2 GB(Zion or something,not sure)
- Monitor - LG,15" CRT
- PSU - Don't know
- CPU - Intel i5 6500/6600
- Motherboard - A good motherboard with 7 to 8 USB Ports in the cabinet.
- GPU - None
- PSU - 500 W Best Power Supply Units
- Monitor - Which gives best view and will not strain the eyes as I will be staring on it day and night.Preferably with inbuilt quality speakers.
- RAM - 8 GB DDR4
- Mouse - Wireless
- Cabinet - Spacious enough to accommodate evrything
- Keyboard - Good quality one,nothing fancy
- Headphones - Wireless
- OS - Windows 10 new & original (in dvd)
- Hard disk - 1 TB
- SSD - No
- Optical Drive/DVD writer - A good quality one,nothing fancy
- This should go for a long time,may be adding another 8 GB RAM in future.
- Preferably Kolkata.
- No
- Trading in the Stock Market
- Chess (for chess, Graphics card is not needed,the processor is target area)
- Download rig
- Watching HD Videos
- Intel processor is preferred and MSI mobo gave me a bad time,so don't want that brand.
- Gaming - n/a
- Desktop - 1920x1080
- No
- Windows 10
