my desktop pc is not starting. sometimes the power light at the back comes on, sometimes not.
for a few days it was not coming on then today it did but after few minutes of it working it turned off. now when i try to put it on it makes a high pitched alarm and doesnt come on.
called a repair guy few days back and he said he couldnt make out what the issue was so he suggested changing the cabinet & smps.
i've just changed the psu 6 or so months back -(its a brand call DSP; 450w). the iball cabinet is abt 4 years old). is it a case of poor quality psu or it being underpowered ? (though i dont do any gaming or high cpu intensive computing).
should i buy a new cabinet and psu or just buy the psu first and try with the current cabinet. which cabinet/psu would u guys suggest for my usage & configuration?
i've gone through a few of the threads here and no one has mentioned iball. is it really that bad??
also my cpu fan would really go at a high speed (4000rpm+) even with normal browsing it would be noisy as hell so i used to control it with the speedfan s/w and keep it at 65% (1800rpm). cld this be the cause/can this cause problems? would installing an extra fan in the new cabby help?
thnx guys
1. Q: What is your budget?
1. 4k (for both - cabinet and psu)
1. CPU - Intel Pentium D 2.4ghz
2. Motherboard - Intel 801 XXX
3. GPU - NA
4. RAM - 1x1gb, 1x500mb
5. Monitor - viewsonic
6. SMPS & cabinet - iball
7. benq dvd writer
8. hard drives - 1x 160gb WD, 1x 40gb SGT
3. GPU - NA
4. Q: Which hardware component are you looking to buy (component name).
1. cabinet - zebronics/coolermaster elite/any other
2. smps - any
1. Yes, will upgrade the following within 6 months
2. hard disk - 1TB within 2 months
3. RAM - 1GB (maybe)
1. Mumbai
2. Open to online purchase
1. No
1. trading
2. Browsing
3. Desktop Processing
4. occasional video conversion (of movie rips)
5. Download rig, 24x7 operation
6. streaming HD movies to ps3
1. no
1. NA
11. Q: What is your preferred monitor resolution for gaming and normal usage
1. Desktop - 1440x900
1. No
1. Windows xp
thnx guys
3. GPU - NA
7. benq dvd writer
3. GPU - NA
2. smps - any
1. Mumbai
1. No
1. trading
2. Browsing
1. no
1. NA
1. No
1. Windows xp
