broksindri
Novice
I got dell 3542 old laptop (I3 4th gen) it has 64bit 2015 build windows10
I am not able to connect my earbuds to it,
It detects my earbuds in bluetooth settings (Refer capture01)
It shows as connected when i try to connect (Refer cap 02)
But earbuds is not available in PLAYBACK devices (Refer cap 03)
Also the earbuds start blinking led light even after a connection with laptop (Blinking light indicates not paired)
I even tried another bluetooth headphones , faced same issue with that too.
i dont think bluetooth hardware has issues, since i can connect other accessories to it like wireless controller.
If anyone faced such an issue pls advise on solutions , i already tried loads of solution available on the internet.
I believe every issue in PC has some workaround,,hoping to find for this one too
TIA
TIA
