Please help me find a 1 ton fixed speed window ac
Anuj333
Explorer
Hey there guys, hope you're doing well.
So, I'm looking for a 1T window ac, non-inverter. Usage will be less than 5 hrs per day, that's why opting for a fixed speed one. Also, currently renting out, so don't wanna go with split ones.
Budget is around 30k. So, OG and Mitsubishi are out of question. Based on views I've heard online, I'm leaning towards carrier or hitachi. I'd have gone with daikin but as of now I don't see any offering in their window ac.
Please share your opinions on what you guys think would be the best. :) Thanks!!
1) Carrier Estrella Ex, CAW12EC3R34F0
2) Blue Star WFE312L
Carrier has better cooling and quieter than bluestar but less efficient. You can get both under 28k I think, check which has better service in the area that you live and go with that.
Reactions: Anuj333
between the two, the carrier has a cooling capacity of 3300 watts vs 3100 watts for blue star one. That's why the bluestar seems to have lower electricity consumption/more efficient which in actual is not.
