Hi all,
I am planning to build a system with following configuration
AMD Athlon II X2 - 260
GIGABYTE GA-78LMT-S2P
Corsair DDR3 RAM (2x2GB)
Sapphire ATI HD 5670
I will be using the following items from my old PC
Seagate 5400rpm SATA HDD 250GB
Samsung DVD-writer
Samsung 18.5" monitor
Right now i am confused about the PSU. I have two PSUs in mind
Corsair 430W CXV2UK
Seasonic S12II-430W
Can you kindly let me know whether these PSUs will support above config?
I will be using the system for light gaming ( RPGs with low resolution and low settings if needed, as long as they have decent FPS)
Your suggestions are highly appreciated. Thank you.
Samsung DVD-writer
Corsair 430W CXV2UK
Seasonic S12II-430W
