kaduvag
- What is your budget?
- 28-30K
- What was your existing hardware configuration (component name - component brand and model)
- CPU - AMD550be
- Motherboard - BIOSTAR TA790gx
- GPU - 650ti
- RAM - Transcend 2GB DDR2
- Monitor - Viewsonic 24inch
- SMPS - seasonic s12 520w
- HDD segate 500g
- key board&mice - logitech bundle
- Monitor - viewsonic
- GPU - 650 ti
- CPU - FX6300
- Motherboard - any compatible motherboard(except gigabite)
- RAM - corsair vengeance 4gb*2
- HDD - 1tb any brand
- dvd drive - any compatible
- cabinet - antec, coolermaster, corsair (below 3.5k)
- this is my final.
- Cochin
- and online purchase
- Yes/No
- Gaming
- Browsing
- Desktop Processing
- HTPC
- Download rig, 24x7 operation
- Watching HD movies
- Do not want to buy XYZ company product as I heard the after sales service in India is pathetic
- Strategy - Civilization 4
- Racing - Grid at medium to high settings
- Gaming - mid or high settings
- watch HD movie
- No
- Windows 7 64 bit
