A anfjavid Disciple Oct 29, 2010 #1 hello guys, i came to know that total video converter is best for converting/encoding video. But i want to know the best container/format - video codec clubbing for getting the best quality video with good compression. Please suggest guys..
A anfjavid Disciple Oct 30, 2010 #3 No i want to convert to PC format. I am not bothered about compression for mobile.
GuruGulabKhatri Level F Oct 30, 2010 #7 ^^ +1 They are the Dopest. For Minimal Quality Loss Listen To What tommy_vercetti Recommended. IMO x264/AVC Using A Higher (3.1 or greater) Profile Is much Better Than XviD/DivX Also for an Audio codec aac Is fab (Use The Nero encoder Not the Faac),A perfect Portable avatar of Ac3 use Size Wise Compression rather Than Bitrate wise AutoMen (Mini Mencoder Gui) 6 beta 06/10/2010) - Doom9's Forum - Is a Good Tool to Start with - Lots Of Info about it Here - Automen: a small yet brilliant video converter | freewaregenius.com Hope this Helps
