Hi Everyone,
I am helping my brother to build a system for Lighting & rendering. Need your suggestion for that also if any improvement/ change needed then your comments are most welcome. please suggest which to chose
I will be using Software like Unreal engine 4+(Most), 5
D), Maya (Most), Houdini, Substance Painter, Adobe Photoshop & Aftereffects, Foundry Nuke & Katana, and Renderers like Arnold, Vray, Renderman, Redshift etc.
Edited
Thanks
- What is your budget?
- Around or below 1 Lakh to 1.3 Lakh
- Building a PC from scratch
- Build 1:
Processor: AMD Ryzen 9 3900X
Motherboard: MSI components MPG X570 gaming plus
GPU: inno 3d2070 super (haven't heard much so please suggest)/Galax 2070 Super
Power: Antec earthwatts Gold pro 650W
RAM: g.skill 2 x 16GB
Cooler: cooler master ML240L
Storage1: crucial Nvme 250GB
Storage2: Seagate/Wd 1TB HDD
Cabinet: Cooler master K501L
Build 2:
Processor: AMD Ryzen 7 3700X or 3700XT
- (please mention the rest in above format)
- Build 1:
- Yes, this is my final configuration unless you guys recommend something else . will upgrade the following maybe after 6-8 months
- Secondary storage - will add another TB
- Mumbai
- Open to online purchase for few parts
- No
- Animation(Lighting and Rendering)
- GPU rendering
- Gaming
- Browsing
- Sometimes overnight rendering( yes only sometimes)
- Watching HD movies
- Not really
- 1920 x 1080
- Ram , CPU maybe
- Windows 10 64 bit
- Linux - CentOS (might install after few months of use)
Edited
Thanks
