You can try Advanced Zip Repair at : http://www.repair-zip-files.com/
It should enable you to extract the files from your incomplete zip file. Just out of curiosity , what contents does the ZIP file have? If it is just text documents and stuff, you could recover a part of it. However incomplete EXE files etc will just not work.
