Storage Solutions Problem with my DVD Drive! help!
Aditya
heya guys,
I just transferred every part of my PC to the ThermalTake Xaser III..
Everything works perfectly! Everything. Except now my DVD-RW (HP dvd640) doesnt work.. at all, the dvd-rw doesnt have any power.
I thought its a PSU Problem (as now i use 2 HDD Coolers on the hard disks + 5 LED Fans), so i went and put it in my other PC, where my CD-RW works properly.
Same thing happens, no power at all.
Is it like a wire has burnt or something?
It was bought from USA, its still under warranty..
Can i take it to a HP Center here? :(
Can i fix it by some1 else?
Hmm, you can take it to an HP service centre, no issues, tell them to check the drive and say you'll pay if they don't accept warranty, its fine that way :)
