I have an intex 600va UPS about 5 years old and have changed battery twice now. A month ago it wasnt working properly so when i checked i saw that the plug had burned. UPS plug was inserted in a spike buster and that socket too was melted plus the plug of spike buster was also burned.
Then i changed the spike as well as the plug of the UPS. Worked fine till yester. Suddenly no power was coming into UPS and when i checked the UPS plug again burned and melted and the new spike socket also has melted but spike's plug is proper.
What could be the problem? Is it a faulty UPS or faulty spike or fault with switch board. i will try replacing the plug once more. If its a faulty UPS please suggest if its worth repairing and if not please suggest a good UPS around 1.5k.
Thanks in advance.
Thanks in advance.
