Problem with x360 controller in Burnout..
hirumon
Contributor
hi,
i bought an xbox 360 wired gamepad...
its working fine in POP and assasins creed..
how can its be used in burnout paradise...
when i go to controls menu only keyboard controls are there..
pls help me...
Yup there is no menu afaik, just start using it and it will work. I am using it.
RT=ignition+acceleration
LT=Break
A=Nitro
B= E Brake
Left Stick to control vehicle.
Right Stick for camera.
RB/LB=toggle menus
Thanx for the advice...
when i restored default controls game pad controls came automatically...
You can simply re-configure them according to your preference in the same way as a keyboard. Double click the action and then move or press the corresponding button on the keypad.
