CPU/Mobo Problems due to Low power supply
IceFusion
Inactive
Forerunner
Well i would like to know what problems would indicate that my power supply isnt sufficient for my computer....cause most of the local PSU's in india do not provide more than 200W power as i have heard...
ICE post your rig naa... Well there are lots of things which might indicate to this. Abnormal Hangups... Abnormal Shutdowns... GPU getting really hot... And the likes...
The following is a list of PC problems that often are power supply-related:
1)Any power-on or system startup failures or lockups.
2)Spontaneous rebooting or intermittent lockups during normal operation.
3)Intermittent parity check or other memory type errors.
4)Hard disk and fan simultaneously fail to spin (no +12v).
5)Overheating due to fan failure.
6)Small brownouts cause the system to reset.
7)Electric shocks felt on the system case or connectors.
8)Slight static discharges disrupt system operation.
In fact, just about any intermittent system problem can be caused by the power supply. Of course, the following fairly obvious symptoms point right to the power supply as a possible cause:->>
/*But obvious reasons, huh!!!*/
A]System is completely dead (no fan, no cursor)
B]Smoke
C]Blown circuit breakers
Source
My rig :
P4 3.0ghz
Intel 865GBF mobo
2*512mb DDR 400mhz ram
ATI 9600 128mb gfx
Liteon 16X DVD writer
Samsung Cd writer
1*80gb+1*160 GB seagate HDD
17" LG flatron monitor
TVS gold keyboard
Iball laser mouse
A typical symptom of a underpowered psu is it restarting either when you log into windows or when you are starting a game. Basically when the ram or gfx card need extra juice.
