Problems in BSNL ULC1100 plan.
channabasanna
Inactive
Contributor
Dear All,
I have been using the BSNL Broadband for the last 5 years. Had been using the Home 500 plan till recently i upgraded to ULC1100 plan (2MBps upto 10GB and there after 256kBps) from May 2010, now a days (past 2-3 weeks) i am facing the following mentioned issues with the internet. Have not crossed the 10GB limit for sure this month.
The Issues are:
  1. Whenever i open gmail, or orkut i get a invalid page. After restart of the modem it works fine. (both Router and Modem are restarted, 1st Router and then the Modem)
  2. When i do open some sites i get 500 Error, this gets resolved or continues even when i restart the modem.
I had never faced this issue last month nor when i was using the Home 500 plan. Is this an issue with the BSNL, or is it some other issue. I am using DLink 300 wireless router along with the main BSNL Modem (HUAWEI modem i think). I am using Kaspersky Internet Security 2010 both on my PC and laptop.
Do anyone of you have faced the same issue, and resolved it. If so please do let me know how you people resolved the same.
Regards,
Channabasanna
How will that work. I mean using Google DNS instead of BSNL DNS. Will the IP be same, or will it be changed too. Will do try by using the Google DNS today.
your ip will remain will the same,just click the properties of your adapter using for connecting to the internet,go tcp/ip v4,properties,and change dns servers to 8.8.8.8 and alternate to 8.8.4.4
Then perform a traceroute to check if its all working,and pings are all reasonable.
edit:
8.8.8.8 and 8.8.4.4 are google dns servers
