Problems Regarding NFS Shift 2
GuruGulabKhatri
Galvanizer
Hi I just installed NFS Shift 2. after installation when i Started it Up Id Showed an errpr like Phsyxloader.dll Not found So i downloaded the PhysX 9.10.0513 Driver and Installed.The Game launched but only to a black Screen and Hung.
Is it because i Have an ATI card?Please help
TIA
Do one thing, remove physx and then uninstall the game. Also, delete registry of physx(if you can,might help) Then reinstall the the game and install physyx from the game cd/dvd itself. try it.
Have you tried updating the video driver? Install the latest 11.8 and check. Played Shift2 on my 5850, runs perfectly. If you are using the *ahem* version, the exe might be acting up.
