Hi Guys
Need an external storage solution, so am looking at procuring a 160GB/250GB HDD with 3.5" USB casing.
Having checked up a bit on our forums, I guess Seagate and Hitachi are the most recommended options. Since I haven't used Hitachi before, I am a bit skeptical towards trying that out just for now and hence would like to stick to Seagate (though it runs HOT ).
Pls help me with the following:
1. Which interface should i go for SATA or PATA? Is 7200.10 PATA even available?
2. Which casing? No Vantecs for me..I need this to be the best VFM option. I'm okay with a PATA HDD if a PATA-USB casing is significantly cheaper than a SATA-USB casing. Approx prices if possible pls.
Requesting quick response as I'll be buying this tomorrow morning.
TIA
Cheers!
TIA
Cheers!
